I clay coated a couple daggers. used fireplace high temp caulk that comes in a tube. Take a compass with a pencil and mark an even line all the way around the blade depending on blade width how far in you want to harden. then put masking tape from the cutting edge to the pencil mark. Apply a good heavy coat 1/8" - 3/16" of the cement over the blade, while still wet pull the tape slowly and it will leave the cutting edge evenly exposed all the way around. set it a side for a few days to let it dry. Bring it up to heat checking the exposed edge regularly, as soon as the edge is up to non magnetic quench point down.The cement will help keep the heat from getting to the center portions and also keep it from cooling to quickly. Cement will usually fall off as the blade cools.
Good luck,
Bill
