Question about ER Fulcrum EI
I've been searching through the web to find best deal for ER Fulcrum, and found two different kinds of full size fulcrum.
one the original, and other the EI version.
could anyone tell me the differences between two of them, other than the fact that EI got the EI stamp on the blade.
thank you
Don't understand the Question.
ER has the Fulcrum II Folders. 1 is a Tanto and one is Spear point. The the Fulcrum FBs-
The Fulcrum bayonet
The Regular Fulcrum Tanto( Big FB) In Testudo and Geocam Those are the Fulcrum S.
and the Fulcrum C, witch is a smaller version of the Fulcrum S.
OH, And the Fulcrum K9 Fixed blade. It's the same as the Fulcrum S but it's called the "K9" because it meant to "Kill dangerous stray dogs when a firearm would risk hitting the wrong animal".
Those are all the Fulcrums I know about. Otherwise, all the ERs have the Same N690co steel. thick tough blades that come shaving sharp out the box. the Steel Remind me of 154CM just but tougher( Probably because of thickness) and the edge last longer. One of my top 3 favorite steels. it's the same Steel as the Spyderco Hossom Fixed blade series that are insanely high priced.
Blade Length: 7"
Overall Length: 12 1/8"
Blade Thickness: 1/4"
Blade Steel: N690 Cobolt Stainless Black Testudo Coated
Blade type: Tanto point
Handle Material: Black anodized hard Kraton
Weight: 13.1 ounces / 300 grams
this is the spec of normal fulcrum Im talking about. EI is the special version of this. But I really do not see any differences between the one Im about to buy and the EI.
