- Feb 3, 2010
I was planning to purchase a spool of 4lb. Fireline yesterday for my ultralight spinning set up. They had limited options and the only 4lb was crystal. My question is:
What is the difference between original and crystal? Prefrence?
I understand that the 4lb. has the diameter of a normal 1lb line. I use a small Shimano symetre 500 reel with an ultralight St. Croix rod. Should I get 8 lb. Fireline, so it will be stronger, or should I still go with the 4? Obviously I want thin line, but should I take advantage of using stronger line so I dont lose the big fish? Maybe 6 lb.? Always thought anything over 4 lb was blasphemous on an ultralight.
Ended up getting a spool of Flourocarbon for the time being. Figured I would ask before I started spending $30 on line.
Thanks in advance for advice.
