I've searched, but can't seem to find an answer on here or general Google search.
I'm trying to build a friction folder with a one sided handle. Chisel ground knife will lay flat on surface of handle. My question is about the pivot...
When using a pivot consisting of a barrel and two screws, what prevents the screws from loosening as you open and close the knife? While waiting for some pivot samples, I'm using a temporary Chicago screw (barrel nut and 1 screw), and it loosens quite easily as I open and close the knife. I'm not using washers as I want the blade to sit as low as possible on the handle. This probably involves some pivot theory, but again, can't seem to find anyone explaining how a pivot should work properly anywhere. Thanks in advance for any suggestions or info.
CM
CM
