hollow grinds make the blade alot thinner at the edge yet leaves thicker material on the back of the blade to keep it stiff, this means you can get a finer edge, cut throat razors are probably the best example of this. the disadvantage is the edge is weaker, this istn a problem for a razor or a gents folder but a working knife the edge would probably be too weak. youre right to a certain extent that its easy to manufacture, if you think about it the natural shape a blade would take if it were gound on a wheel would be a hollow grind so its easy to make with probably the most common grinding tool but not necessarily inferior, depends on what you want it for as do many things. knife edges are always a trade off between edge 'sharpness' and retention and edge strength, usually to get more of one you have to give up some of the other for example my fallkniven A1 is a convex grind difficult to do but its an exceptionally strong edge and although i can get it to slice paper its not a hair popper, I have a few flat ground knives, there middle ground, they will pop hairs but the edge isnt as strong, but they dont compare to a cut throat and a good quality hollow ground knife will take a better edge too (of course im assuming theyre all decent blade material etc) its just to do with the angles if you think about it the angle of a hollow grind is alot sharper than of a convex grind. draw profiles on a sheet of paper to convince yourself. the eternal struggle between sharpness and strength...
