I've got some mosaic pin material that I picked up at Blade '04 and am anxious to use some on a couple of projects. Problem is, I'm not sure how to use it. I was hoping some of you more experienced makers might dispense with a few pointers
When you put the stuff in a handle, do you acutually flare the ends, like you would with a brass or other type of pin? Is it cut into thin "discs" and used over the top of a recessed hidden bolt? Or is it just put through a hole in the tang, and holes in the handle scales, and held in place by epoxy? Any feedback is most appreciated, fellas!
