I took the Chit BAS I recieved Thursday for a workout. I cut the same brush as I did with the WWII Villager. Magnolia limbs, crape myrtle (sp) and some oak limbs and a few oak logs. I also chopped into the oak with the front of the blade. The limbs were anywhere from 1/4" up to 2".
The WWII handled it all with no sign of anything except some sap on the blade. The BAS cut well but showed signs of some chipping along the forward part of the blade, from the sweet spot forward, especially at the tip.
I looked the blade over, and noticed that when viewed from above, the left side was ground nicely convex, but the right side was flat to (almost) looking hollow ground. This is only right at the tip portion of the blade. The WWII seems to be more flat ground than convex.
I thought no problem, so I went in to steel the blade and use some sandpaper on it to get rid of the chipping. While I did get rid of the chips, it seems like the blade loses a lot of metal while sharpening. I'am using a very mild steel and some 2000 grit paper to polish the edge a little. I also stroped the blade for a good while on a nice fat piece of leather. While it got fairly sharp (dull shave) it seemed to lose the edge very fast.
Question:
1. Is it common for these edges to need to be broken in a bit with several sharpenings to get to a little harder metal?
2. Does this seem like an issue of the temper possibly being a little off? (to hard?)
The chips were not huge. Just enough that you could see breaks in the edge line. These chips happened before I had really sharpened the edge. I had passed the steel over it maybe ten times per side. I had passed the blade over the leather before this as well.
Have you had similer experiences in the past with these blades when new. I know there are many variables here. I'am outta here for the night. Please let me know what you think. The knife is great so far in every other way that I can see so far with the short time I have had it.
Question:
