Question about PID and toaster oven!
So I have an entire cart built on amazon to wire up a PID to my toaster oven. I’m a little nervous because I know knowing about electrical, and honestly my time is so limited these days that’s it’s just easier for me to buy something already built.
came across this: Inkbird Heating or Cooling PID Temperature Controller IPB-16S Pre-Wired Digital Home Brewing Controller Independent Control Pump Thermostat https://www.amazon.com/dp/B06WD6X17V/ref=cm_sw_r_cp_api_i_ei1hFbM4C58ZC
is there any reason this wouldn’t work? If not is there a pre-made solution that I could buy that would require limited setup?
thanks a ton BF for dealing with my newbie questions.
well, for one thing, the operating temps for this unit as listed are -58 F to 257 F, which you will be (I hope) exceeding when tempering your blades.
Dang I thought I read differently. Is there something like that will support up to say 500 degrees? Or should I just pull the trigger on the amazon cart? Lol
Have you searched for and read the other threads on PID ovens and forges on the forum? I can only speak to the components I used on my build.
