Hi everyone, as you all noticed I'm new to the forum. As a beginner knife maker, I have made my research and came across a few methods of annealing, heat treatment and tempering steel. But still I rather ask here, where there are people who make knives for a living and know what they are doing. For sure there is someone out here that has also tried making knives/blades out of round saw blades.
Like everyone else who first started knife making, I made some mistakes and I learnt the hard way. Without doing any research I bought a 3 foot 3/8 inch x 6 inch flat bar of steel made of "Hardox 400". Talked with my friend, and he told me that I need proper heat treatment, annealing, tempering techniques for every kind of metal. I read about it, and it's totally useless for making knives. Anyways, after that I decided to find some circular saw blades, since good steel is very hard to find around here unless I get it shipped in (But the cost of shipping to Canada and steel is too high on the net). I came across a man trying to sell his old circular saw blades. He told me that they're at least 15-25 years old and that most of them are made out of High Carbon Steel. I assume that the big blades, those which are very rusty are made out of High Carbon Steel and a few smaller ones are also High Carbon Steel. I know that the ones with carbon teeth, usually the body isn't made out of good steel since it's just the teeth doing the job. Those saws usually don't rust because they contain a very small amount of C % and more Cr %, which is more likely stainless steel or not good steel at all
I will post some pictures after my text, below the thread for you guys to see and tell me your advice or help.
A very professional knife maker once told me that saw blades make a perfect knife/blade/sword if I follow these simple rules :
1. Forge or grind to shape
2. Finish to preheat treat level
Shape and rough finish all components of the knife such as bolster, handle, etc., etc.
leave blade edge thicker than finished edge at this point
2a. When forging --- normalize X 3
Normalizing is done by heating to about 100*F above critical
(red-orange or non- magnetic) and air cooling
(to reduce stresses in metal created by hammering and deformation of steel)
Heat to (orange red) and allow cooling to air temp X 3
3. Heat treatment
Heat to non-magnetic approximately 1450* and quench in appropriate quench medium.
(This depends highly on the metal you are using at the time)
Quench mediums and heat treatment ranges are sometimes supplied by the company
that supplies the steel, I.E. (Admiral Steel)
4. Temper
Take steel directly from quench medium to an already preheated oven, and heat at
400* for approx. 2hrs.
Making a clean patch on the tang will help you to be able to recognize the color
change from blue to light straw color more easily
5. Finish to final stages
sanding, polishing, and final fit for components
6. Final assembly
7. Final blade edge
Obviously not the same temps for different kind of steel, and maybe some different steps along the treatment.
He told me to treat the less rusty saws like stainless steel with 12% Chrome, which is D-2 Steel . And to treat the rustier saw blades without carbon tips as L-6 High Carbon Steel . And the saw blades with Carbon-Tungsten teeth, not to use at all unless I experiment with it since the body is made out of cheap steel.
- Are these good advice given by my friend ?
I heard that some blades are made out of High Speed Steel but the ones without carbon teeth usually have a good High Carbon Steel body.
- Is this true, if so, how can I differentiate "HSS" from "HCS" ?
Here is the link for the pictures; this is my first time converting pictures into url, so if it isn't working or showing up, please tell me and I will try to repair.
OR
http://village.photos/members/aZZeee/My-Photos
Any advice or help given will be gladly appreciated.
Thank you for your time and I wish you all a Happy upcoming Christmas !
Bye .
3. Heat treatment
4. Temper
6. Final assembly
7. Final blade edge
OR
Bye .
