a few side notes about infi swords -
one of the benefits of infi is not only that it can take a lot of lateral stress, but in the way that it takes it. ats34 at 1/4 will take, say, 400lbs lateral torque and then snap off with no bend. infi will take 450lbs, then start to bend a little, at 600lbs, it begins to get to the setting point, at 700 it takes a set. im not sure if it would break at any given point, so im not going to let it be an option in this example. those numbers were taken completely out of the air and in no way reflect the real world numbers.
so, what you end up with is a steel that will require more presure to start to bend because of the high hardness - but will bend under enough pressure because of the characteristics of infi.
the lower the rockwell, the "tougher" the steel will be, the the easier it is to bend. i wouldn't be suprised if the torque numbers were considerably lower for a traditional katana to make it take a set then they are for an infi sword. after that, it all in how the edge holds under heavy use, wich infi is known for.
in regards to spring tempering the back - jerry has said that infi doesnt take well to differencial hardening or spring tempering, because of its ability to transfer heat throughout its matrix easily. it might be possible to acheive it with enough effort time and money, but with how well infi reacts at high hardness, the gains probably wouldnt be worth it
