- Feb 24, 2000
A number of years ago I bought a vertical blown forge from Uncle Al. It had 1" layer of kawool covered with satinite and ITC100. I used it for a number of years to make Damascus until it needed a new layer of kawool.
While I was re-doing Uncle Al's I bought another vertical blown forge. I won't say where I got it. It also had a 1" layer of kawool covered in satinite and ITC100. A couple of years ago I got a pyrometer and was surprised to find that the second forge would not get hotter than 2,240 degrees F. I tried more gas, less gas, etc. The hottest it got was at 3 lbs. If I raised the poundage even a little the temp. went down. If I lowered the poundage, the temp went down. I had the blower wide open. Yesterday I used it to make some san mai and it took the forge 45 minutes to get up to 2,000 degrees.
Meanwhile I had re-done Uncle Al's forge. I put 2" of kawool and covered that with satinite and ITC 100. I decided to try out Uncle Al's forge. In less than ten minutes the forge had reached 2,450 degrees and was still climbing. I used the same pyrometer in both forges.
I can't understand why the forges didn't work pretty much the same. I don't think 2" of kawool would make that much difference. What's wrong with the 2,240 forge?
