DaQo'tah Forge
Banned
- Aug 26, 2002
THE SITUATION : Okay,,,,in the morning I plan my 3rd attempt at making Damascus steel. I'm using about 30 sections of banding strap that is cut to about 6 inches long, This is spaced with about 20 sections of Bandsaw blade that is also cut to 6 inches long each.
I have welded one end, wired up the bundle with tie wire,,,and welded a re bar rod to the welded end.
Now I know how to use the 20 mule team flux, but I have a question about the smacking with the hammer part.
QUESTION: when I begin to set the weld , what end do I hit?....I'm not sure if I'm to start hitting the bundle of steel up by the welded bar,,,or should i first hit the steel out near the end and work my way back to the bar?
THE PROBLEM:,,,Last weelend I tried hitting the heated steel out on the un-welded end, but this sorta bunched up the layers of steel as I worked my way back toward the re bar handle.
Do you experts start hitting the bundle of steel near the welded-on re bar handle?
