Professor
- Apr 6, 1999
I've noticed that the Bone Collector's blade tang ramp where the Axis module interfaces is radiused, which in my estimation reinforces the three point blade contact between Axis module, pivot pin, and stop pin, making for rock-solid lockup with absolutely no vertical blade play. The mini-BC is fast becoming my favorite EDC of all time.
Other Axis models I own, inclusive of the large Onslaught, Adamas, and H20 folder all have a hint of vertical blade play and they do not have the radiused area on the blade tang, just a flat ramped interface surface. My Adamas in particular has play that simply will not disappear no matter how much the pivot is adjusted or if I allow the Axis module to "slingshot" forward when the blade is opened, which on other models will tighten the lockup and reduce or eliminate altogether the vertical play. There exists absolutely no side to side play on my Axis models as I've adjusted/Loc-Tited the pivots to my preferred "hydraulic" opening and closing feel.
My question is, does BM plan on incorporating the (IMO "improved") radiused blade tang ramp on other/all models at some point? Perhaps you are already, and I just don't own those models.
Thanks for your response, and by the way, I'm very pleased that you have a presence here now! Hope to see you at Blade this year.
Prof.
Prof.
![IMG_1107[1].jpg IMG_1107[1].jpg](https://www.bladeforums.com/data/attachments/171/171226-a1e1f711ba5513dda95a987c79a57360.jpg?hash=oeH3EbpVE9)
![IMG_1108[1].jpg IMG_1108[1].jpg](https://www.bladeforums.com/data/attachments/171/171228-7859268d33f62595695a282e11531cde.jpg?hash=eFkmjTP2JZ)
![IMG_1110[1].jpg IMG_1110[1].jpg](https://www.bladeforums.com/data/attachments/171/171237-1fa955e0477c5ff6823a3cd5350459cc.jpg?hash=H6lV4Ed8X_)
