Question for CRK pros
Hey fellow CRK nuts. I just received my new large Inkosi from knife art and the pivot and action are very stiff. Can I just loosen the pivot a hair without taking it apart and then applying locktite? I like the action stiff, but not quite this stiff. Thanks.
It should work itself out with a few open close but yes the pivots are adjustable hence the inclusion of loktite in the box.. I find if you are just backing it off a hair, then no need to pull the whole pivot screw out to reapply loktite, my stayed where I adjusted and doesn't move.
It will wear in. Open it and close it a couple 100 times. It's the tight tolerances that your experiencing. Will get smoother and smoother over time.
Yes you can.
The locktite gums up once the initial seal is broken, but the gummed up locktite will stay in the threads. So, there's no need to worry if the pivot screw will back out.
