Question for Dan
This may be obvious to most but could you explain the term,Mid-Tech Production Run?:confused: Thanks chickenplucker :thumbup:
"Mid-Tech" is a relatively new term in knifemaking....and to be perfectly, frankly honest....unless you mine the ore for your steel and grow your own trees for handle material...you are participating in some degree of "tech"... :D :p
That said, the term refers to knifemaking that is neither factory made nor solely handmade...but something "in between".
For me, that "in between" means having the "roughing out" done out of shop...by machine shops.
Here's a rough comparison to give you an idea.
For a knife to be purely handmade by me, the following is done "in house".
  1. Profiling barstock on a metal-cutting bandsaw
  2. Clean-up perimeter on the belt grinder
  3. Drill handle holes
  4. Chamfer handle holes
  5. Grind "45s" to start bevels
  6. Grind bevels
  7. Heat-treat (simple carbon steels only - O1, 5160, 1095)
  8. Clean up after heat-treat
  9. Finish blade "flats" to final finish
  10. Finish bevel grinds to final finish
  11. Etch (if needed - for damascus, hamon lines, or as a patina)
  12. Split handle material (if in a block)
  13. Cut out (profile) handle material
  14. Drill holes in handles
  15. Counterbore handles if using corby bolts
  16. Profile handle fronts
  17. Taper fronts on an angled platen
  18. Finish fronts out completely
  19. Prep for glue-up
  20. Glue-up
  21. After glue-up, grind down pins
  22. Grind off excess handle material around the profile
  23. Rough shape, adding contouring where needed
  24. Begin finish sanding
  25. Bead blast (synthetic handles only)
  26. Complete final sanding
  27. Chamfer any lanyard tubes
  28. Finish the spine and tang
  29. Deburr corners
  30. Finish sanding inside the choil
  31. Etch logo
  32. Apply finish (natural materials only)
  33. Sharpen
On the first Bushmaster Production Run, the following was done "out of shop" (highlighted in red)
  1. Profiling barstock - by waterjet
  2. Clean-up perimeter on the belt grinder (a must, even - and especially - with waterjet cutting)
  6. Grind bevels
  7. Heat-treat - by Paul Bos
  11. ---n/a
  12. ---n/a
  20. Glue-up
  25. Bead blast
  29. Deburr corners
  30. Finish sanding the choil
  31. Etch logo
  32. ---n/a
  33. Sharpen
And for the BushMaster Mid-Tech Production Run, this is how it will run:
  2. Clean-up perimeter - by machine shop
  3. Drill handle holes - by machine shop
  4. Chamfer handle holes - by machine shop
  5. ---n/a
  6. Grind bevels - by machine shop
  7. Heat-treat - by machine shop
  8. Clean up after heat-treat - by machine shop
  9. ---(see next)
  10. ---stone tumbled finish on blade, flats and tang - by machine shop
  11. ---n/a
  12. ---n/a
  13. Cut out (profile) handle material - by waterjet (synthetic only), natural materials done "in shop"
  20. Glue-up
  29. Deburr corners
  31. Etch logo
  33. Sharpen
If I could do a run where it was almost entirely automated, I would...but it would be a Factory Production Run...and I still would do a good bit of hand-fitting and finishing. But that would not overtake my handmade and mid-tech runs...it would be separate....and mostly just to see if I could make it work. ;)
But, as you can see - with the BushMaster list above - it's really only part of the work done "out of shop"....so that's what makes is "Mid-Tech"...and neither purely handmade, nor truly a factory production.
Because I have this done "out of shop"....it saves on cost...but more importantly it saves on time....my time. I can increase production quantities without sacrificing quality, since I do all the final finishing myself - just as I would with a regular ole handmade knife.
Thanks for asking the question....hope it's not too long of an answer. :foot:
:thumbup:
Dan
Great explanation Dan of just how many details and steps you guys go through.:eek: It really shows in the finished product.:thumbup::D
Sure thing, Bro.
Thanks for the kind words.
Dan
