- Jun 22, 2003
mrostov said:Home Depot usually has a pretty good selection of Nicholson files. They make surprisingly good hones.
That chakma/file/saw/chisel I made a while back out of a Nicholson file has proven so far to be such a good sharpening surface that unless I really do a number on the edge, I seldom need to use the EZE-Lap Model M diamond rod sharpener I keep in a loop on the frog.
i did the search on any posts relating to it, and i found pictures, but not much info on it. i just recently smoothed out my 18" ang khola's chakma so that one side is rounded instead of rectangular. i cant come up with any logical reason why a corner is better then a circle - my limited experience has shown that the corner will stripp steel off faster then the circle. turned out really nice, but your file/stee/saw/chisel looks so much cooler
i have a set of nicholson files, and come monday im going to be order a couple of sheets of 3/8" micarta slabs for handle material, but i have a few questions about the chakma you made.
is the steel portion one of the edges? (the thin side of the rectangle), or one of teh flats? (perhaps flat+edge?)
are the saw teeth angled (into a pryamid, instead of a prism), or are they flat on top? (kind of like making the file marks that are already there bigger)
i assume that you didnt do any kind of annealing, but i thought id ask anyways: was there any kind of annealing performed on the file?
how did you attach the handle? if with appoxy, what type?
where did you get your handle material/what material is it?
it just seems like such a well rounded tool to have in your bag that i decided id have to make one to see for myself
thanks
