- Dec 16, 2000
My question is: those who forge your own blades with a propane forge, what is your preferred burner orientaion? The forge being a horizontal cylinder and the burners coming in from either directly on top aiming the heat directly down or the burners coming from the side creating the "atmospheric" setup. The problem i've found with the burners oriented from the side, which was my first propane forge, was that the blades heated more quickly on the side with the burner. this normally isn't a problem with regular forging where the pressure is high enough so that the forge becomes nearly the same temperature throughout and brings pieces up to bright orange at roughly the same time but when the pressure is set low enough so that the blades will only reach a bright red for heat treating operations, they heat unevenly, because the forge doesn't fully heat up. I'm building a new forge and i'm considering orienting the burners from the top and I was curious as to how everyone else who forges their blades has theirs. I know of atleast one bladesmith who supports each orientation method, so i was curious what others prefer.
Thankyou for the help
- Loren
- Loren
