Originally posted by Uranium
Also for you people who like to chew on pens:
Those super crappy erasable pens made by PaperMate are PRESSURIZED, I found out one day when I pulled on the metal tip and it came off, and it shot 3 inches of the most viscous, oily, impossible to remove crap all over my hands. I can't imagine what I would have done if it did that in my mouth![]()
Originally posted by Dexter Ewing
Roller balls are classified into two categories: regular and free ink. The regular type roller balls (e.g. Sanford Uni-Ball Grip) use a cotton resevoir to hold the ink. The ink is then fed through to the tip. Free ink rollers (e.g. Sanford Uni-Ball Vision Elite, Pilot V5/V7 Rollers)) have a resevoir that holds the actual liquid ink. The free ink styles write smoother due to the free ink flow. Almost like a fountain pen.
Ball points use a thick, almost gel type ink. Gravity feeds the ink against a tungsten carbide steel ball and the ball then transfers the ink to the paper. Pressurized ball point cartridges such as those manufactured by Fisher Space Pen, rely on a thick gel type ink almost the consistency of rubber cement. The ink is forced against the tungsten carbide ball by pressurized gas. The action of the ball rolling across the paper "shears" the ink and liquifies it, allowing the pen to write. Because of the gas pressure on the ink supply, this is why Fishers are famous for being able to write in zero gravity, upside down, withstand a variety of temperatures, and also survive airline travel.
Hope this helps.
