After sharpening on belts for a while, I pulled out my Sharpmaker.
Am I supposed to raise vertically the handle as I bring the blade down the stone when using the flat side?
Or am I supposed to keep the spine of the blade more or less parallel to the surface?
Or am I supposed to move the handle slightly away from the stone so that the edge remains in contact with the flat of the stone as I pass through the belly and to the tip?
If I bring the knife down while remaining more or less parallel to the table, then the knife's edge - starting at the belly and continuing to the tip - is only touching the edge of the stone. I think the angle of the edge also changes and becomes more acute if you use this method.
Depending on the length and profile of the blade, if I keep the blade perpendicular to the length of the plastic box, then I have to make an exaggerated lift of the handle to keep the edge in contact with the flat of the stone. I think this also changes the angle of the edge as you move through the belly and to the tip.
The other option would be to move the handle away from the stone as the stone starts to touch the belly and continuing through the tip. (Similar to the way most lift the handle when moving through the belly when sharpening freehand or one a belt.) If you do it right, this would appear to me to keep the edge angle consistent. '
To test this, I took a scandi grind Mora and kept the edge flat to the stone. Assuming the angle of the scandi grind on the Mora is consistent, then a slight lateral movement of the handle away from the stone is needed as you pass through the belly.
What to you guys think? I've watched a couple Youtube Sharpmaker videos and people don't seem to be moving the handle laterally. Maybe they are changing the edge angle at the tip without realizing it.
It's been a long time since I watched the Spyderco instructional DVD, but I don't remember this being discussed.
(Not really here nor there, but I see a lot of how to videos using a 1x30 belt sander on Youtube video where it appears many are lifting the handle too much. Of course, it depends on the blade profile, but it didn't take much lifting to keep the scandi grind flat on the stone. I see a lot of people really lifting that handle, which would make the edge angle at the tip less acute.)
