Daniel, Here is what I do: Quench blade down to 150 degrees or so, imerse in water to cool down to about 60 degrees, dry off and direct into the liquid nitrogen. The objective is to keep the process moving, with out a pause so the retained austenite will not have a chance to stabilize. When you slide the blade to the LN2 do it in one quick fluid motion. I use 154CM, S30V, S90V, 10V and 420HC. I have never had a blade crack or ever seen evidence of any incipient cracking. Leave the blade in the LN2 for at least 2 hours, more will not hurt anything and does not seem to help either. I have left them for as much as 24 hours. If you have blades with a very thick flat section next to a very thin ground section or have San Mail like Ed Shemp reported then the snap temper would be a good idea, but you will not get the full benifit of the process. The higher the soak temp you run the more retained austenite you will end up with, as much as 30% in some cases. You can resolve the RA by tempering but it would have to be at higher temperatures to be the most effective. The objective then is to resolve the RA by the subzero and then you can temper at lower temps for maximun toughness and corrosion resistance. I have used this method for fillet knives which must flex even when at high hardness. At RC 60 with S30V I can bend the blade past the elastic limit, where it will not spring back and then restore it back to normal by bending the other direction. Phil
