- Jul 7, 2002
got a bit adventouras the otherday, an used a product called,
super lube.its made by synco. multi purpose sythnthetic lubricant with syncolon.??
it sprays on wet, then you wave it around a bit, the khuk that is,
an it penetrates an drys in about 40-60 secs put the khuk to one side did the same to karda + chakma, then decided to give the inside of the scabbard a good spray.
sure makes the khuk slide in an out nice an smooth. i will let yous know how it goes in use, and how its anti rusting is. regards ghorka
the following is a list of its claims.
safe to use on anything that slides swivels,rolls ,or squeeks ect.
withstands temperatures between -45 deg f t0 450deg f or 232 celsius. only gets to about 50-60 celsius here??
[might have to sit in the oven with the khuk an see what happens] hee hee
forms a nontoxic anti corrosive shield that prevents rust and is completly impervious to saltwater,
and is usda h2 authorised for use in federal meat and poultry plants.
also compatible with most other lubricants.
so sounds good to me i will be givein it a tryout[ be a guiny pig] an let you know.
