- Aug 14, 2009
Hey steve I've just spent all night reading throughout your forum and thought that you might be able to help me. If you're familiar with the Bradley Alias or the Benchmade 755 you'll know that the lockbar has a step toward the end of the lockbar's travel. I bought a used Bradley Alias 1 about 6 months ago and alas the lockbar has finally wore its way to the step and there is very noticable vertical blade play. This knife has been fitted in the past with two seperate custom g10 scales each made from a different maker (Before I owned the knife). One of them was better fit than the other but both changed the lockup when installed. On one it makes the lock preatty darn sticky upon release and the other locks and unlocks great but it has side to side play no matter what I do. In the past I have used it extensively with each installed and I think it may have damaged the knife doing so.
I also just bead blasted the knife with my new media blaster using "medium" grit glass bead. I'm a newby to blasting but I duct taped the washer area and the lockbar face so as not to change the finish/lose material in those spots. I bought the glass media at my local Harbor Freight and don't know how aggresive it is compared to others. I thought that also the glass might be a high enough grit that it actually removed enough metal in the stop pin holes that there is a bit of stop pin play. What kind of media do you use?
I was wondering if it would be possible for you to grind down the step in the lockbar face so that it could wear the full way like most framelocks. Possibly in combination with milling a new slightly larger diameter stop pin.
By the way after checking your sub forum out I really like the kind of work you do and how you take so much pride in your testing of knives to find out how to make a better one. I believe that you are a maker that is going to blow up in the knife industry.
