afishhunter
Basic Member
- Oct 21, 2014
Which is the finer grit, the BLACK or TRANSLUCENT?
I probably will.Get at least one of each and let us know what you think.
Dan's are worth the extra you will pay. Not only are Dan's Black's high quality stones they have a reputation for being flat and pretty much ready to go. If you really want to see what a black ark is capable of doing it should be flat and lapping a hard ark isn't the way to spend a Sunday.I probably will.
I will probably need the black at least, to smooth a nib or three.
You are right about that! I just FINALLY got a small black Arkansas stone flat after giving up on it several times before. Damned thing turns 36 grit sic powder into 600 grit powder in about three minutes. Turned my xtra course DMT plate into a fine DMT plate, too. And that's with a 4"x2" stone! Purchased it decades ago from Williams Sonoma.If you really want to see what a black ark is capable of doing it should be flat and lapping a hard ark isn't the way to spend a Sunday.
I forgot to mention that.Dan's are worth the extra you will pay. Not only are Dan's Black's high quality stones they have a reputation for being flat and pretty much ready to go. If you really want to see what a black ark is capable of doing it should be flat and lapping a hard ark isn't the way to spend a Sunday.
I know some years ago Sharpening Supply's arks were rebranded Dan's, probably still are. My experience with the company has been all positive.
I agree the color doesn't signify the quality. However, with the possible exception of the translucent stones, the black are harder/finer/denser than the lighter "soft" stones.The actual color makes almost no difference. Stones are graded by their density. A lot of people insist on grading quality by color. I have a number of Dan's stones and all of his stuff is exactly as he describes it - it's really a big family operation and they care about their customer base.
Regarding the question re: will the Dan's stones cut...I agree the color doesn't signify the quality. However, with the possible exception of the translucent stones, the black are harder/finer/denser than the lighter "soft" stones.
For what I wanted it for; polishing a fountain pen nib, upon further research I'm not sure if the Dan's black or translucent will work. They may be too coarse, at least for the final polish. I need 8000 to 12000 grit for the finishing polish.
I still may get the 3 piece Dan's pocket stone set for my 1095/440A/420HC/1.4116 KRUPP/up to 9CR18MoV blades though. Admittedly, I probably don't need more than the "soft" stone for a fine edge on them.
Question:
Will Dan's stones cut 5160, S30V, D2, and CPM154, or are those steels harder than the stones?
Question:
The factory edge on my 2-dot 112 was THICK behind the edge and OBTUSE at the edge. I finally fixed that with some SiC wet/dry sandpaper, quite a number of years after having put the knife out of my sight in frustration, after I'd attempted reprofiling on my Arkansas stones. The 'ease of sharpening' threshold, between those two sharpening options, is radically different, depending on which side of the fence you're on. Buck's 440C was too much for the Ark stones, but SiC ate it for breakfast. That was one of the best sharpening lessons I could've wished for - like an epiphany for me, at the time. Pics below were taken sometime after I'd made that knife one of my favorites, after shunning it previously for many years.Obsessed with Edges
Reprofiling (which they needed) or just sharpening Buck's 440C back in the day with the stones that were commonly available was a minimum of a nightmare, wasn't it?
I know a few who switched from their pretty much "unsharpenable" (with then available stones) 110's for a sharpenable Uncle Henry LB7, when they came out in '78(?). Or if somewhat wealthy, got whatever Puma lockback the same size as the 110, before the LB7 came out.
I know at least one of my classmates from '71 to '74 carried a Puma lockback with Stag covers.
I suspect if Buck had used a 25 to 32 degree inclusive edge instead of thatobtuse duller than an axe 50 to 60 degree inclusive convex edge, (which was known to sometimes be rounded when the blade was polished) they (a) wouldn't have been so difficult to sharpen. They wouldn't have needed reprofiling, either ... unless you wanted a 18 to 20 ~ 22 degree inclusive edge.
I wore out my first 112 (440C) on carborundum stones; Arkansas hones just didn't work. Much prefer Buck's 420HC these days, or S30V, like my Custom Shop 112.The factory edge on my 2-dot 112 was THICK behind the edge and OBTUSE at the edge. I finally fixed that with some SiC wet/dry sandpaper, quite a number of years after having put the knife out of my sight in frustration, after I'd attempted reprofiling on my Arkansas stones. The 'ease of sharpening' threshold, between those two sharpening options, is radically different, depending on which side of the fence you're on. Buck's 440C was too much for the Ark stones, but SiC ate it for breakfast. That was one of the best sharpening lessons I could've wished for - like an epiphany for me, at the time. Pics below were taken sometime after I'd made that knife one of my favorites, after shunning it previously for many years.
