- Aug 26, 2005
I had some primers not go off in my 44 mag .That big click is not much fun . It was ammo I received when I bought it way back when . The dent in the primer seemed to be a little shallow . It was hand loads . I don,t know if they might not have been seated properly or in some other way defective . I would like to eliminate the revolver as the source of the problem . Is there an easy way to clean the firing pin mechanism and whatever else might gum up the works ? Is the revolver likely to be the problem . I can,t go back to the range easily as I must receive a written invitation and a lot more red tape that you would not believe .
