- Jun 5, 2002
As we all know, as a liner/framelock knife wears in, the liner will slowly start to move across the blade towards the right hand side. I always assumed that what was wearing and causing this to happen was that the face of the liner and the face of the blade, where they engage each other, wears slightly from friction, in effect, making each one slightly shorter, thus, since there is now empty space, the bend will cause the liner to move to the right to take up that slack. But, it occured to me that this might not be the case, rather, its not the liner/blade surfaces that are wearing and causing the liner to travel, but the stop pin becoming slightly bent downward from repeated impacts, which will also cause the liner to move to the right to correct for this extra slight amount the the blade will be higher than it was relative to the lock face.
So, to you makers or knife lovers who know, which is it, or is it both?
Thanks.
Thanks.
