- May 30, 2001
I have a question on peaning pins,I am praticing on some stock metal
before I try it on my first knife.I am useing nickle bolsters with nickle pines.after I am done peaning them i make a pass or two over with a belt sander to make them blend in and then I am hand rubbing to a 800 grit then buffing with white compound,they are so bright you can see your teeth in them.My question is when I move the blade in under the lights I can see a faint circle were I put them in and worked them
done,is this common or is there something I could do like counter sinking the holes or somthing else so they can not be seen. I would like to hear some input on this.
Thanks a bunch
Thanks a bunch
