- Dec 24, 2005
I can't find the list of woods that do not require stabilization... Anyone have it ?? thanks...
Wood was used for centuries before stabilization. In my opinion, not all woods can or should be stabilized. We've learned a little about which woods react well to being stabilized.
When I write about stabilization I'm referring to professional stabilization by companies like K&G and WSSI. Immersing wood under vacuum in Minwax Wood Hardener, tung oil, linseed oil or polyurethane is not the same as professional stabilizing. The chemicals are different and more importantly the results are different. If you choose to do your own stabilizing you should tell your customers. Letting customers think wood has been professionally stabilized is the same as buying damascus and letting your customer think you made it. If you do your own stabilizing buy a good moisture meter. We've found wood responds better to stabilizing when the moisture content is 6% or less.
Woods Than Responded Well To Stabilizing:
- Acacia
- Afzelia
- Alder
- Amboyna
- Black Ash
- Bamboo
- Beech
- Beefwood
- Birch
- African Blackwood
- Box Elder
- Bubinga
- Buckeye
- Canary Wood
- Carob
- Chechen
- Cherry
- Coolibah
- Cottonwood
- Carpathian Elm
- Elm
- Eucalyptus
- Gum
- Jarrah
- Koa
- Locust
- Madrone
- Santos Mahogany
- Maidou
- Brown Mallee
- Red Mallee
- Mango
- Maple
- Masur Birch
- Mesquite
- Mulberry
- Oregon Myrtle
- Tasmanian Myrtle
- Needlewood
- Australian Oak
- Oak
- Olive
- Tasmanian Olive
- Osage Orange
- Paduak
- Black Palm
- Red Palm
- Pecan
- Pink Ivory
- Pistachio
- Purpleheart
- Redwood
- Russian Olive
- Sandalwood
- Sapele
- Sheoak
- Sycamore
- Tambootie
- Teak
- Tulipwood
- Vitex
- Black Walnut
- English Walnut
- Wenge
- Woody Pear
- York Gum
- Zebrawood
Woods With Limitations:
- Bocote - May Weep Stabilant
- Ebony - Scales Only
- Asian Ebony - Scales Only
- Striped Ebony - Scales Only
- Juniper - May Weep Stabilant
- Snakewood - Scales Only
- Thuya - May Weep Stabilant
- Claro Walnut - May Turn Black
- Pacific Yew - May Weep Stabilant
- Ziricote - May Weep Stabilant
Woods Where Stabilizing Did Not Work:
- Cedar - Stabilant Did Not Polymerize
- Curly Ipe - Stabilant Did Not Penetrate
- Lacewood - Wood Turned Black
- Limba - Wood Turned Ugly
- Merbau - Stabilant Did Not Penetrate
Woods We Have Not Tested:
- Cocobolo
- Desert Ironwood
- Kingwood
- Lignum Vitae
- Bolivian Rosewood
- Honduran Rosewood
- Indian Rosewood
- Verawood
If you have questions feel free to ask.
__________________
Chuck Bybee
chuck@alphaknifesupply.com
http://www.alphaknifesupply.com
Thanks Scott, That was the one !!:thumbup: Now if I could just find a ball bearing...![]()
