- Dec 20, 2011
ok guys, when I got into knives about a yr ago the first 'hobby quality' blade I got was a Delica for christmas.
Ever since then I havent used it a whole lot but enough that I've had to resharpen it. The sharpening system I'm using is pretty shoddy. Im using a old lansky guide system and I tape sandpaper to the old hones, although it isnt the best method I get pretty good results with every other steel I have including s30v.
The problem I have with the vg10 is ive never been able to get it to take a keen edge. The other day I was sharpening my izula and was checking the bevel out underneath my microscope. Since I had the scope out I looked at the delica and the edge was chipped to hell.
Although it hasnt been used a whole lot, when I have used it I cut up some really thick 3/4" boxes at work. I have used cheaper steels to do this task and they dont take the same abuse the vg10 did assuming thats what caused the chipping, it was awhile ago. Basically what im asking is under use like that is vg10 prone to chip out all crazy like that or do you think theres a possibility I have a badly heat treated blade?
The blade came out of the box really sharp but havent been able to get it to take even a somewhat satisfactory edge. I have never even seen any of my cheaper blades chip out like my delica has.
Sorry if some of this doesnt make sense to you all, I'm still pretty ignorant in blades compared to most of you.
I appreciate any ideas, suggestions!
Thank you!
Thank you!
