there is no correct answer to your question, it is not specific enough, nor does it provide enough information.
All of it depends of how thick the piece is, to some degree how large or small the austenite grain size is (was, actually), how hot you get it, and the type and temperature of the oil.
In general, motor oil is not the best, it is slow. You would be better served by using quenching oil. Barring that, some kind of vegetable oil would be preferable, and heat it up some. Or better yet, use water at about 110-120F.
Regardless, the whole blade should be tempered for stress relief, with the option of drawing the spine back softer if you wanted to by selectively tempering it hotter. if the whole blade hardened. That is unlikely if it is a large blade, and you quench it in any kind of oil. In that case, you would most likely get only the edge to harden, with the spine and body being made into pearlite, which is not a bad thing.
