Question Re: Blade Finish
I just received a handmade that has a mirror finish. I noticed several places, e.g., the spine, butt end, and near the choil, where the finish is cloudy or milky-looking. There is a term for this but I can't recall it. I believe it's caused when the polishing or finishing wheel jumps or runs off the edge abruptly, sort of out of control. Please enlighten me :)
Was the knife new? If so, maybe the maker just did not pay enough attention with his final polish to a few areas. If it is used, someone may have used an abrasive to clean up those areas and scratched the surface slightly. I have had to clean up small areas like this on a couple of older knives that I wanted to be perfect. It is not difficult if you have the right materials.
If the knife is new and you are unhappy, send it back to the maker for a touch-up. Even it was not purchased directly from the maker, the maker will probably be willing to touch it up for a nominal fee. Otherwise, look for 4000+ grit automotive polish and hand rub the problem areas. It is not very difficult, but you need some Really fine abrasive paper or powder.
Before you do anything, make sure it is not just fingerprint smudges that are clouding up the finish. Use rubbing alchohol or ren wax to clean the knife and then take another look.
Paracelsus
I have had great success with a product called Flitz.
Most gun shops carry it. I would just try some and see if you can clear it up.
Not sure what the term for the smudge is if that's what you were looking for, sorry...
