- Feb 8, 2010
Hello!
I have a WorkSharp MK1 that I have been using for well over a year and I love the thing except it's not easy to sharpen items that don't fall under that 20 degree or 25 degree angles. I also mess up knife tips pretty frequently. I saw that they are coming up with an upgrade to the WorkSharp, the mk 2 that gives you increased speed control and what appears to be a permanent guide that can be switched between 20 & 25 degrees as opposed to the mk 1 guides that have to be switched around. I was wondering if I should get it or if I should just spend more money to get the Ken Onion that just gives you even more options as far as angle in concerned. The other question I have is: does anyone know if the WorkSharpMK2 will use the same belt size as the original?
Thank you!
Thank you!
