Hi all! I'm designing a HT oven for myself. I've read tons of threads on here about people who have done it, and I've watched all sorts of videos on youtube. I have a couple of questions I was hoping you guys could answer...
1) When I use the formulas on Kanthal's website to determine the diameter of the wire I should use for the element, it looks like for a power of between 4.2kW and 4.8kW (18-20 amps at 240v), and an oven that can go up to 1100C, the appropriate diameter of wire should be about 2mm. This would equate to 12awg. But it looks like nobody here uses wire that thick? As far as I can tell, the thickest anyone is using is 13awg. Am I missing something?
2) Also according to the Kanthal website, it looks like if I wanted to use 12awg wire and wrap it around ceramic rods, the ceramic rods would have to be 1inch in diameter to fit Kanthal's recommended geometry. Is this correct? Is anybody using 1inch diameter ceramic rods? I searched for those online, and they are ridiculously expensive. It looks like people who are building ovens with elements wrapped around ceramic rods are using 1/2inch rods.
3) The oven I'm designing will have a 6"x6" chamber. The length is dependent upon the element coil design. If I route grooves in the walls and don't use ceramic rods, then according to Kanthal the 12awg element would need to be formed into a coil with a 1/2" diameter. If I build an oven with grooves in just the walls (a "U" shaped coil on each side, with the sides wired in series), the oven interior would end up being 6x6x31.5" to fit the length of 12awg coil I would need. If I route grooves in the sides and also the top, then I would use 3 elements and the oven interior would be 6x6x22.5". I'm a little concerned about putting an element in the ceiling, as I worry about sagging over time... My goal is to make kitchen knives for friends and family. I don't see any swords in my future... Anyone have any recommendations or advice on these oven sizes? The smaller oven would be 0.46875 cubic feet, and the larger one would be 0.656 cubic feet. At 4400W, that equates to about 9400 and 6700 Watts per cubic foot respectively.
Thank you for your advice!
Darren
Darren
