Questions about grinds. What to use?
Northerr
Banned
So im buying this knife.
Kershaw Spec Bump
Ive honestly never even looked into grinds before.. i didint even know they existed until i read this forum. My question is, what grind is on my knife, whats the best grind, and can i apply it at home? Thanks in advance.
This link will tell you about different grinds Blade Geometry FAQ
The Spec Bump has a Flat Grind according to the link you posted. Most likely the edge is a V bevel. What's best is a matter of opinion and usage. Theres really no way you can change the grind of that knife, but you can change the edge geometry (though probably very unnecessary) .
Do you plan to sharpen it yourself or have it sharpened at a shop? If yourself, make sure you get a sharpening system that will work with recurve blades.
Get a Spyderco Sharpmaker and you will be good to go on everything but convex edges.You can even touch them up in a pinch also with the Sharpmaker.
Cool, thanks.. any chance you can explain how it works? theres not much of an explanation online... something about 15 per side or 20 per side degree grinds but nothing about concave/convex or otherwise. What do i need to sharpen different kinds of grinds? and are there any good sharpeners that hold the knife for you, so you can get a more even bevel?
That link doesn't seem to work. Is this what you have? I don't know anything about it, but if you have already used it and it works, then you could just keep using it. Although I don't think it will ever get a knife truly sharp.
I personally use a vertical belt sander to sharpen my knives, but A) it wouldn't work on that knife because of the blade shape and B) it takes some practice to know what you're doing. I know that Lansky and DMT make attachments for recurve blades for their systems but I don't know how well they work. I've never used a Sharpmaker but it looks like it would work too.
Here is my suggestion.
1.) Buy a system that sharpens one side at a time. The Sharpmaker has been suggested. Seems a tad expensive to me, but I'm cheap. Buy a cheap knife with a similar blade style (look at eknifeworks.com or budk.com, you'll probably find something close for less than 10 bucks). Read the directions that came with your sharpener, and practice on the cheap knife until you know what you're doing.
2.) Find someone in your area that sharpens knives and have them do it.
I think you're confusing "primary grind" and "edge grind". The "primary grind" is the overall grind of the knife. It is rarely changed from the way it origanally comes. The "edge grind" is how the very edge is shaped. It is usually shaped like a V and is sharpened at different angles depending on how the knife will be used. Sometimes the edge will be convex, chisel, etc., but I bet that if you look at your knives, they probably all have a V grind. As for holding the knife. The Lansky and DMT systems clamp onto the knife and use guide rods to keep a consistent angle. I think with the Sharpmaker you just hold the blade straight down, so it would still be very consistent.
The main thing i would stress is to not learn on a $130.00 knife. Buy a cheapie and practice on it. If you want a good knife without all the sharpening hooplah, you can get a Mora for $10.00, and they are easy to sharpen by hand even for a novice.
