Ahoy to everyone, I am brand new to your forum as of today, and I had a couple of questions for some of you experts out there. I tried searching the forums for this info, but I haven't found it yet. Sorry if these questions are repeats.
1. I have the Razor Sharp Edgemaking System which has worked really well for me so far. I am wondering about how much wax to apply to the silicon carbide wheel though. On the instructions it says things like, "Touch the wax to the wheel each time you start to sharpen." and "The Grit wheel is going to seem very aggressive the first 4 or 5 knives until it looks smooth and waxy. Be careful not to put on too much Wax. If you do the Grit cant do its job!" I'm trying to be careful with the amount of wax I put on, and so far I've had no problems. However, I am noticing that wax is starting to build up a bit on the wheel now, so I'm wondering if I should back off on the wax. I guess I'm wondering if anyone has advice about how you can tell if you have too much (or too little) wax on the wheel. Also, I'm curious if there is anything you can do about having too much wax on the whell. I suppose you could grind off the wax and start over with applying silicon carbide, but that seems a bit extreme. Any insight would be greatly appreciated.
2. What is the makeup of the white rouge included with the set? Is it diamond paste? "Blizzard compound"? Something else? Can you use a different compound to substitute for the one that they give you?
Thanks in advnace!
Thanks in advnace!
