Questions about ScotchBriting
flash900
I remember a thread a few years ago about ScotchBriting, but it did not explain exactly what that is.
I know it when I see -- but how is it done?
Is orange peeling another name for ScotchBriting?
If so, would you also beadblast after doing the orange peeling?
I want to have this done on scales, not the blade.
Thanks for your help.
Scotchbrite is a belt used to finish or clean steel depending on its grit. In pads, It’s the material that is used to scrub pots & pans. Available at most hardware stores.
Thanks, Laurence.
So what is orange peeling -- and is that completely different than ScotchBriting?
Slightly off topic, but I had an ultra fine Scotch belt break on me a couple days ago. Man, it jerked the blade out of my hand and threw it down harder than I possibly could have if I would have tried! I’ve had a few belts break in the last few years but this was probably 5X more aggressive of a pop and grab than I’ve seen with a belt before.
If you don’t mind, I have a couple questions. What grit would you sand the blade to before using the scotchbrite? What type of scotchbrite do you recommend? I am trying to improve the finish on my blades. They tend to look smudged and have micro scratches when I try to hand sand.
i go to A65 gator belt then blue scottbrite belt with some black buffing compound loaded into it
There are four colors, most aggressive is Brown, then Maroon, Blue and super fine is the Grey . I may have the last to mixed up. I haven’t been in the shop for a while. Had to have my spine operated on. ———————I suggest you start with real 3M Scotchbrite belts. There are other brands. I take my blades to 220 grit and then the Maroon belt on down. I’ve also just gone to 120G and started with the Brown coarse Scotchbrite & down. I make Culinary knives so I Don’t like a mirror polish. I want a brush satin finish. We all work out our own systems/progressions of grinding & finishing our blades I suggest you Buy all four. You’ll be surprised by all of the uses you will find like reconditioning a old rusty blade etc. the belts last years if you do do something stupid like put the tip of a sharpened knife into while reconning it. Ask me how I know!:rolleyes:
