hey guys
1 i have great trouble resharpening because i have hard time determining and getting back to the right bevel angle (i do sharpening free hand), is there a trick or way to get it right directly without trial and error and ending up with several different bevels on the edge alone? (speaking of course on resharpening using the grinder)
2 my 'manual' sharpener is spyderco's tri angle, same problem goes when using it, because i have trouble determining the angle and its set to use with 40 & 30 degrees
3 i just finished a tanto few days ago, my first double edge, sharpened the main edge fine but trouble came with the swedge.
A its curved upwards, B the belt i used was not even at the sides, so kept 'wobbling' which created more trouble. so after ruining it a bit i decided i will get it as thin as possible then continue on the sharpener.
not only did the sharpener get it more dull than it was (have no idea how or why), while using it this happened
the other side is about the same
any thoughts on how to fix this and do a better job sharpening?
my current plan is cover the main bevel with tape, sand this then resharpen with grinder, anything better or advise on techniques?
thanks
thanks
