silenthunterstudios
Slipjoint Addict
- Feb 2, 2005
I fell into a great deal on a 03 Silverado, 4.8 V8 Vortec, after my accident. Family helped to get it roadworthy, and I lucked out. Had to buy parts, and get some work done by a family mechanic, but still came out not too bad. I've been driving this truck about a month, and it is far and above better than the 85 extended cab Toyota pickup I was driving before. I don't feel like a grizzly bear driving a Dodge Omni anymore (yep, had one of those too when I was about 17).
When I first drove it, it would idle at about 400-500 RPMs, and stall if you put it in Drive, or stopped at a light etc. Looked online, and found it was an easy fix, clean the throttle body. Man, I've never felt a truck get up on plane, like a speedboat, before. Got that fixed, ran like a charm. Gas guzzler like a wino with cheap strawberry ripple, but I thought that was because it's an 8 ft bed 4wd truck!
Check engine light came on, I took it to a local auto parts store and they came up with the PO332/P0332 code. Bad knock sensor. I haven't gotten around to getting them replaced yet, but I'm not done yet. I have noticed a bad shift from first to second, after doing some research, this is something common to this model (coming up on 80k, I've put about 2K on it in a month, 90 mile round trip to get to work and back). I have been religiously checking the oil, and found that it was a little low. I put about a quarter of a quart of Supertech 5W30 (5W30 is recommended) in to top it off, didn't overfill it. That was a couple weeks ago. My uncle had changed the oil, and used Valvoline 5W30 I believe. I did read that Supertech was crap (been putting it in all of my old jalopies up until now), that Supertech was fine and should prolong a vehicle's engine and that you should only use Mobil One, Valvoline, Quaker State etc. In the past few days, I've noticed that the oil pressure gauge, which idled around 40, and got as high as about 50-60 when reaching 2500-3300 rpms (highest I've gotten is 3500 RPMs when getting onto the highway, it hit about 4000 RPMs tonight which scared the crap out of me), is idling at about 25, and maxes out at about 45-50. I checked the oil last night, it was full, checked again tonight, and it is full. I had a Change Engine Oil warning come on the odometer since I've had it, I was told that was a bad code. I was able to reset it by turning the ignition to on, and feathering the accelerator three times. Got a Oil Setting reset message, and this was after the oil pressure gauge "issues".
Over the past couple weeks, I've noticed the engine continuously working harder to get speed. When I first started driving, I just had to barely touch the accelerator and she would take off. Now, she still gets up to speed quick, but needs a little more pressure on the gas. In the past few days, it seems like it's been working a lot harder, and while it isn't knocking, when I give it some gas on the highway (most of my daily commute is on major highways) it is a lot louder.
Since I've been driving, I've been driving junkers. Even though this truck is almost ten years old, it's the nicest truck I've ever owned. I know most forum members replies will be to get it checked out, but I am afraid of it blowing up on me in the interim. Internets research :foot:
has revealed everything from blown head gaskets, to bad oil filters, to just needing to replace the oil sending unit. I thought the acceleration issues and poor MPG (about 15-17) were related to the knock sensors needing to be replaced. The hard shift from 1st to 2nd and the oil pressure has me really worried. I did read however that 20-25 is fine for about 2000-3000 rpms, with 6 (not 60) being ideal for idle.
Any thoughts are welcomed, this isn't WC though
. Hoping I can drive it to our family mechanic, and possibly get the codes scanned and get some reset, and at least get a feel for what I need to have done, tomorrow. Going to need a ride to work if that's the case. Luckily, my mechanics shop is in the same commercial park as my fathers auto upholstery shop. About a 35 min trip, as opposed to a highway trip 45 miles to work, and then about an hour in bad traffic to my fathers shop, not knowing if I'll catch my mechanic before he closes up.
I thought deciding between a locking hard tonneau cover and just a tool box were gonna be a pain in the ass.
