Its a reproduction wwii knife, one purpose blade i want for my collection. I ask about the steel because i collect knives that are ready for work. Its a poker pretty much. What would be the optimal heat treat for either steel? What would be the better steel?
This is my two cents but since you want a knife for a collection I would advise to go with RWL-34 as it has significant higher corrosion resistance.
Here are pdf's for you to see the heat treat recommendations.
RWL 34 Highest edge strength - Michael West
http://michaelwest.dk/knive/rwl34-datasheet.pdf
From the manufacturer Damasteel:
http://www.damasteel.se/files/7613/6963/9883/Damasteel_Martensitic_Stainless_Steel_RWL-34.pdf
You will notice the recommended tempering temperatures and obtainable hardness range from HRC-58-64. The tempering process of 4 and 5 include deep freezing to -80 degrees Celsius or -140 degrees Fahrenheit. Those are IMO the tempering areas that will provide the best balance between edge retention, toughness and corrosion resistance.
RWL-34 is IMO one of the best all around steels available with high obtainable hardness, corrosion resistance, edge stability, toughness, strength and wear resistance.
If you want higher corrosion resistance have a look at 12C27M from Sandvik, however, to prevent warpage it is recommended to do plate quenching of the steel. Most makers today can do post heat treat grinding however care should be taken not to overheat the steel.
EN45 from my understanding and research is the same as S7.
S7 pdf from Crucible:
http://www.burgessknives.com/media/S7.pdf
S7 falls into the category of a Shock Resistant Tool Steel according to my resource Steel Heat Treatment Metallurgy and Technologies by G. E. Totten.
The following characteristics are expedited.
Resistance to Cracking: Highest of the group
Approximate Hardness: 47-57 HRC
Machinability: Medium
Thoughness: Very High
resistance to Softening: High
Resistance to wear: Low to Medium
Here is an article on enhancing the wear resistance through cryogenic treatment:
Click on this
If heat treated correctly and at HRC of 57 EN45 will outperform RWL-34 in toughness. However, you will have limited corrosion resistance. RWL-34 will be a good balanced steel between properties and require less maintenance.
On your previous question....at 57HRC IMO you are wasting RWL-34. RWL-34 IMO should be somewhere between 62-64HRC with cryo treatment. At 57HRC you will struggle to beat EN45/S7 for toughness.
