I'm on the path of improving my sharpening skills and knowledge.
I've just read the following books: Sharpening Made Easy by Steve Bottorff, Knife Sharpening Made Easy by Stefan Steigerwald, and The Razor Edge Book of Sharpening by John Juranitch. I have two sharpening DVD's by Murray Carter which I haven't seen yet. Prior to all these, I went through some youtube videos. I've also read some of the threads here on sharpening.
My questions on angles are these:
1) Does everybody (majority) believe in having both the Secondary (or relief) edge and the Primary edge? I guess those who use convex edges don't believe in this?
2) If the primary bevel is 22 degrees, then the Secondary bevel needs to be smaller than this but by how much? And what about Japanese knives which is suppose to be 16 degrees, what should the secondary bevel be? I'm asking the second question in particular because I have Shun knives.
3) I think I understand why the secondary bevel needs to be smaller than the primary so that as the primary is cutting, the cut part won't rub against the secondary bevel (hence it's called the relief). But what if the secondary bevel is made to be as smooth (or refined) as the primary? Can the secondary angle be the same as the primary (meaning just one angle) if the surface is ultra refined?
Thanks for your help.
