- Oct 1, 2000
Ok, I am trying for the stupid question of the month. Basically because I am not sure how to ask it.
I have been searching and reading about forging, testing, and using carbon steels and damascus on the forums. I notice that many threads talk about forged blades being tested by bending them 90 degrees without breaking and having the return to about 25 degrees or so. I have tested (to destruction) several Stainless steel blades (ATS34) and find that with enough pressure you can bend them but the amount of pressure to bend verse break a blade is very close. In otherwords the blade will usually snap while flexed instead of bend.
So my questions is do properly ht and tempered carbon steel blades tend to bend more readily before breaking than stainless blades?
What about carbon damascus, does it share that same property of bending before breaking?
If nickel is part of the damascus layers does it influence this bending trait for better or worse?
Is this flexablity trait what makes for better impact and shock resistance of carbon steels over stainless steels?
Is it the forging of carbon or damascus that cause this trait or could I expect a similar response if I use stock removal on carbon tool steels (like 1095 or 1084 or others) if they are ht and tempered properly?
I guess I am so use to stainless steel flexing and returning to center or breaking under flex that I am having a hard time figuring out how carbon steels perform so well and have this ability to flex, bend and apparently resist breaking under flex that will break a stainless blade. Am I trying to compare apples to oranges?
Any help in understanding this would be appreciated. I guess as a "Stainless Steel Stock Remover" I am having a hard time figuring out how blades that will rockwell test ABOUT the same hardness will react so differently to flexing, bending, and breaking.
Thanks
Thanks
