In your case getting the tip not sharp, it may be original bevel grind or you do not keep the angle the same along the bevel.
You
can't keep the primary edge bevel angle the same, because usually the entire geometry of the blade changes completely near the tip on any kind of significantly bellied blade: Unless the original blade secondary grind surface thins out in perfect proportion to the narrowing of the blade (a rare and difficult feat, with the consequence of tip fragility), if you keep the edge bevel angle the same on a thickening blade cross-section ratio, the edge bevel will then "broaden" tremendously as the blade thickens in proportion to its width: This is -fairly- easy to do, but tends to look not so great, which is why almost all "professionally finished" bellied blades will grow duller towards the tip... Unless they happen to have a deep hollow grind, that tapers smaller in hollow radius, deep into the point, and even then the edge bevel's side surface still tends to get wider if you keep the edge bevel angle the same.
Generally, bellied blades will grow duller towards the tip, the deeper the belly the duller, unless you accept an ugly gradual widening of the edge bevel, which doesn't look "professional"... Some deeply hollow ground blades may be able to minimize this, and even some flat ground blades can do it if they are very thin at the edge: This means however, since you can't get something for nothing, that the point on these tends to be fragile, if it is truly going to maintain the same blade geometry/sharpness...
Even so, sharpening the belly to match the rest of the edge is always a tricky proposition for an average user, or even a maker, and the deeper the belly the trickier...: The overwhelming majority of knives/makers go for a simpler solution: The knives open the edge bevel angle at the tip, and so grow duller as you go towards the tip, precisely the most useable part...
I figured this one out pretty good by backlighting the edge while I rested it on my stone, right at eye level. Note the relationship to the angle on the stone and slowly slide it across. As it reaches the belly and tip, you will find you need to elevate the handle to maintain the relationship.
How much (up to a point) is determined by the amount of belly. Straight edges do not need to be elevated at all. The key is to elevate the least amount possible, this will keep the edge nice and acute.
"Straight edges do not need to be elevated at all": This is true, and even slightly curved edges, that are close to straight edges, can easily keep the same sharpness throughout, because the aggravating factor is the radius of the edge belly: The deeper the radius, the harder it is to keep track of a consistent edge bevel angle.
Ideally, knives should start out
sharper at the tip than on the straighter rear edge portion: This is because, while it is easy to maintain the same edge bevel angle on the straight edge portion, the tendency towards the tip is to open, while sharpening, the angle further than what is originally provided...: This means that, to balance things out, the edge bevel should actually be
sharper towards the tip: Fat chance though of ever seeing that: When it happens, it seems more of an accident than intended by design: Usually it never happens on any kind of thick stout blade or edge, but more on cheap crude machetes or the like...
Gaston
