I have two questions on tomahawks that I purchased. I believe that my expectations were probably too high for the products and costs that were spent. I do have these now however, and I thought that it is worth a shot to see if I can get them functioning.
I purchased a Smith & Wesson, green handled, Vietnam-style tomahawk that is very similar in looks to the ones that you most often see these days made by Cold Steel. I was using it one day (really for the first time) and the handle (which seemed rather light and not very sturdy) broke/sheared off at the point where the wood handle went up into the metal. After cleaning/grinding out the wood (and some kind of glue-like materal) from where the handle went into the metal, I have tried to find some handles that would fit into this. Nothing fts properly even trying to carve something down. I wonder where I can get a handle that can be used with this? The metal does not seem to be that bad, just the handle was really weak and poorly made.
I also wonder what it the correct process or methods to get a handle to stay on a hatchet (for example, if I can find one for the S&W)? I have also used several of Cold Steel's various other tomahawks as well, and the heads do not stay on the handles. You (seem to) have to actually buy some metal plates that Cold Steel sells to screw onto the handle below the blade to keep the handle from falling down on your hand.
Anyone have any thoughts on either of these two phenomenas (other than to purchase the top quality versions from A.T. company).
APC
APC
