I have a question.
When grinding the edge bevels, prior to heat treatment, how thin or thick should they be? I understand you will finish grinding after heat treatment, but what is the sweet spot for edge thickness prior to heat treat to avoid the blade cracking (during heat treat), and to avoid having to grind a lot on a hardened edge?
Thanks John.
John, you forgot HUMBLE.Heat treat and steel. Plus, I’m damn good!
Hi,
So basically I bought a magnetic knife strip (baccarat artisan, to be exact), I own baccarat knives and was recently sharpening them. After sharpening them I noticed some small surface rust on the knife strip (must be from not completely drying the blade before putting it back). I decided to take a small price of steel wool and just give it a quick scrub, however that has resulted badly. Some how the knife strip is now unable to hold the weight of the bigger knives and they just drops to the bench.
I don’t know how to fix it, and there is nothing on the internet about what to do. The minuscule scratches on the knife strip is the only thing I can put it down to, does anyone have an suggestions? I thought about maybe the steel wool has demagnetised the magnet? Though it continues to have strength just not enough to hold the larger knives? So that can’t be it, let me know what you think? Also wifey is coming home soon, she going to be pissed.
How strong is the magnet to pull directly off of the strip, assuming you have it affixed directly to that wall so knives hang vertically? I doubt you demagnetized it significantly but you may have reduced the surface area of the knife/strip interface enough to reduce friction between the strip and blade as there would be some drag. I would see if the strip is strong enough first by simply trying to pull it off.
Another option would be to try and hang laterally so there is more steel in contact with the strip.
hi, thank you for the response.
The knife strip is drilled to the walled, the backing anyhow. The magnet still contains its strength to the strip. Undoubtedly very strong still, yes the knives hang vertically to the horizontal strip. Hanging it laterally would not have enough room for all the knives.
At closer inspection there is a series of scratches on the strip now from the steel wool. Wondering whether a buff of the strip itself, smoothing out the scratches might be enough to regain the surface strength to hold the knife maybe?
What's the airspeed of an unladen swallow?
African or European?
