Ok so hear is my off topic thread killer
I am with Dan on this as in don't do it with water.
Now I have only made 8 knifes so my knowledge is small compared to lots of others.
The problems I see are getting even enough heat with out making some kind of forge/oven for the flame of the ox acetylene , as Dan said you want to get the blade up to a non magnetic heat, now you only need to get the part you want to harden that hot but "just that part" is a lot to heat on a kukri. So think about that and try it on a bit of scrap. Once you have found a way to get it up to temp you are about a third of the way there. Water is a easy way to brake a blade, I know first hand. Oil is a better bet and lots of oils are used, for reasons of cheapness I have used ATF room temp and warmed up a bit.
Then you need to temper the blade, this is best done ASAP. As a pace to start try 400 deg for one hour.
I even have used corn oil heated to 370 deg to quench and temper in one shot. photo:
http://www.azblacksmiths.org/events/IraDemo/pages/16KeenerQuench2.html
In that photo you can see that just the cutting part is being hardened,quenched,tempered. The spine is air cooling.
So as you know by now there are lots of roads to get to where you want to go, so the real question is are you going to start on one of them? If you go with the water /tea kettle path let me know how it goes, as I am very curious to the details.
Glass Smith AKA Keener
