- Jan 27, 2002
Fellas,
I've just about got flat grinding down. It's not that hard really. Except for two things I need to work on:
1. My distal taper
2. Blending the top of the plunge line in.
With practice, I will easily be able to taper my blades perfectly, so no problem there.
My problem is what to do with the TOP of the plunge line, where it gets up there close to (or right AT) the spine???
When I am finished grinding the bevel, I have this plunge line that goes straight up to the spine, and I'm trying to figure out how you guys "blend" it in?????
I know that you can lay the blade flat and grind a FLAT area back over from the handle area, to keep the plunge from reaching the spine, but what if I want my flat grind to go all the way up to the spine of the knife????
How do I "blend" my plunge line in????
Any help would be really appreciated fellas.....
1. My distal taper
