powernoodle
Power Member
- Jul 21, 2004
Here is a quick look at the SOG Flash II and SOG Aegis. These are reasonably priced mid-sized, light weight EDC/utility/self-defense folders. SOG folders seem to get a good deal of grief around here, largely because of a well-earned reputation for a cheapy feel and a little blade play. The two examples I have are no different. Both have a plasticky feel, and minor blade play. If thats a bummer for you, you're going to say these knives are junk. If you can get past it - as I can - these knives have a lot going for them.
Both knives pack 3.5" AUS8 blades in full flat grind, though the blade profiles are different, with the Aegis sporting more of a leaf shape with a full belly. Both are assisted openers, where your thumb begins the opening motion and a spring jumps in and does the rest. I find both knives easy to deploy in this regard, as well as being a lot of fun to play with.
Deep carry clips are found on each knife, allowing the knife to completely disappear in the pocket. I like that, as I like to fly below the radar and keep my goodies private.
But I like these knives, and recommend them for those folks who can get past the cheap feel and slight blade wiggle. These knives are not for everyone. If you are only buying one knife, your $45 -$55 might be better spent on a sweet Spyderco Endura, Buck Vantage, a Kershaw or one of the many other high quality knives in this price range. But for those wishing to expand their horizons and give SOG a try, you might find that you like the fast assisted deployment, FFG, light weight and deep clip.
The Aegis has 3 thin rubber inserts on each side, which add a little traction but basically are inconsequential.
The lowest prices I have found show the Flash II at about $42 shipped, and the Aegis at around $54. SOG also makes smaller versions of each (Flash I and Mini Aegis).
Flash II.
Flash II.
