Last few I drilled out I used a 1/4" bit in my drill press. Be very careful as the bit will want to seize in the softer material, lots of oil as you are drilling is highly suggested.
fyi, to avoid the spinning blade of death, please use a vise to hold that thing. The horrific injury a member sustained a while back scared me straight.![]()
Yeeeeowch! I'm sure every machine shop has similar stories "I can get it done quicker if I dont......"This reminds me of an incident where I used to work. The tool room supervisor was working on a project and asked our tool designer to hold a piece of expanded metal while he attempted to cut a hole in it with a 6" hole saw in the drill press. When the hole saw caught the expanded metal, it spun it violently catching the designers finger against a steel back stop. In addition to the cut that required stitches, it broke the bone length wise. The tool designer said he knew better than holding it. He was a tool and die maker for 20+ years before he started designing dies.
