Quick question for the CS rep.
ManRay
Can/will you redo kraton handles if they become loose or deteriorate?
Is there an easy way to fix a loose handle yourself? I read that you can use epoxy but how do you get it deep enough into the small gap between handle and tang? Using a canula/hollow needle might be an option but isn't epoxy to viscously for that?
Gesendet von meinem XT1562 mit Tapatalk
Remove the handle to epoxy it on properly. I've done it a few times.
