Quick review of 2 stone-holding tools
Upgraded my sharpening stone holder setup. Pics and comments on a couple useful new tools I ran across.
  1. Tormek rubber work mat. A 21"x13.5" thick rubber mat. Really sticks to work surface. Has 0.5" raised edges to retain small parts and fluids. I've been looking for a high quality work mat like this for a while, for working on small gun parts assemblies, other small parts tasks, and now for sharpening. Really like this one!
  2. DMT Magnabase adapter. An $11 add-on magnet that you can attach to a standard DMT bench stone holder. If you don't have the DMT holder, getting the combined set is cheaper than buying separately. This is a good solution for any metallic plate-based diamond stones (not just DMT). Although as @adamlau pointed out in a PM, if you have a plate based on aluminum, like the Atoma 140, the magnet won't work for those.
What I like about the DMT holder + magnabase adapter for diamond sharpening:
  • Works for any metallic plate diamond sharpener I have, tested with: DMT duosharp/interrupted plates, DMT continuous diasharp plates, Ultrasharp 2-sided plate, and SK11 2-sided plate.
  • Makes swapping stones/sides fast and easy during sharpening. Versus having to keep popping out those little plastic retainer clips on the DMT stone holder. Totally a nice-to-have, but as anybody who has done a lot of swapping stones with those plastic clips knows, the adapter is well worth $11. :)
  • The whole setup is plastic (except the interior magnet portion of the adapter itself--which is covered with a smooth exterior material) so it's easy to use with water, oil, etc., and to rinse off when done.
  • During sharpening, the magnet holds the stones solid. Solid enough that you can flip the entire holder upside down and even with a heavy plate like a DMT EEF, an Ultrasharp , or the large 10" duosharps, they stay put.
y4mbh6plfaOEHk2XujRSoyaLgEIKJjKiy0G0H9s3Z-OBCGdNO5r0-7KH_EE45vE6vhtsYtdRDBBTTu1TdmxTFlduxReO33AP0zvfz0r9uMGsXewLR8aIL1teeTwLS0SVNURiGZF0tD8SDFw4dHEdz_3Q5-7naAyoqgWXslAIPkv_ramdj5g4gWkw1ZKRMbdclXdXCeqhOL8-OOZ20_CMBnYEQ
y4mrR070MNWxXRVXv2MaR83juBkwiyXEx3f9T1uepJxUyEooK1KyGnZa9AqpGoLVE9gjSbbGX78BzH5HhW__k7bLnGgeIwtKBnPaKLhjeXXuR811xBxHowVcRSSPW1oS8XwCBAGyqAEPe9b-SLte-RgHRmHpE_Mhj_U3Dvm7mMklWpO2ELjuX3BwmcMbiZY766CZnCdDRssPbiQa3BLMeBrTg
y4mduVwZ3B4IVLgPmltj9PpUJkHcZYj8IuiG5QP8e3NLBb3qYg83PIoouxvENeE7OKWtqWZtlOTavNzpbmr3MjjwzJ3ug6B_fyj8C0uc_61LoZVcDQfH9qx7maVG7Aoh_HXQVDAWGpeevIy4c18uA1T2mnW2xCM7jazPdmt5zThDPrm4KXGkQ4_oBBSRzZ9z5kPgLfQCk1GWp__nWSZ_oOhcw
y4mmcin7KH0teBfHtfhTH52huUWFRMMAJ7ne3V8sDxeGavi8iJ62YioJg7K58RPGM2B_kl5rPizkFkvGjxcz5FZhIhqhs7UGCWd8krWGC5x_TCM8NZKsaruBpfBbJcgRRSgUSOsi0FrzogAw1Rpm7Vau4yin7RJPg_kJP4lyaG8gIKd0ayL8aizXq7LDE0nsU9_FfEkGAYdZL-G_8-V0ignvw
y4m4NHcuOHFSnW_TzdrO-PK5I7moALnIiYlRMm1Nfii8CtqRuJ5Rep52XWoM4B9y-32jYAOUfzFY6sK-_b26e7jYPAbsRrCr_aREvKcPyAnPXblkuLUcqcTUWtG3AztI2jDZB5dPQfoJZSoUc5boN9KKix57Al3H-i4TIZGcFZNDBD6exx_TN08SvZO9wO8TUrhwAnKt6cHlsd1oqs7UBRFXQ
y4mSjdi4FhjzyU1KYxEy_ID2FoxkaPDM5_EiUyx2R3-u2KWyTqtF7w35PzsT1fV5M7Sm0TAP9Wrh2kxExJZpz9l1FL_0LIOkCAUeftSb_OrM8hLXf9bNCtPgqAp_BnbsuQ9f7Hcp3u8bcSD8vUUv7KkUF455XI3ja66r7FU58v3UzCPHMNIPUNgnW_iFB0cDXdCKsD2xBMotSrW_cBCcbW9Kg
y4m_VBSBhBe1CX9xbn8XP4xBKsL6NdmQ1eGDhxP8fSTdUC8xDZ7yUh8lRV46tbROhqjKNQbJkA0zPf1XSrIHUGrahgb65xir_zvEspFqcbR8oIg8vbnftU7LqXbyNb8Uax72tc3uIOL2qsIWMmBtFdZhz6sGsLK_YVqGpr4BoeAbzFkWpYrfWtNok-LMMdxfNGKiHmRJk90gFy1QALB4TLVGw
y4m7i_THCR0bIruxCqHEJkgRSK83AWr4tRsRvheZC_-ElRQWjbwk1KqyERhLtgp6LGG7DuADNr-yDASDAU9N26KxFsUEE8CZyk4OXt0FEihcvY4CWdvnBs8sxA-BpsxmjqAeI6yIbF5jD2Ygvg1FZrPb0ALSM1ZmCdPHqNjyBsyTxHYzPsXpAegcq-f7keVbP__H0gWzGcDY9nw9osiIXQL2g
