You're not going to profile the entire bevel to 30° with the sharpmaker. You can slowly knock the shoulders down little-by-little, but doing the whole bevel on the sharpmaker is going to take forever and a day.
If the OP has a Spyderco knife, the odds are the edge is already 30 degrees from the factory. The 30 degree setting maintains that scary sharp factory edge.
It varies so much that each knife should be treated on a case-by-case basis.
That's not an accurate statement. Maybe in your experience. If you want to take my experience, then odds are that the factory edge is around 45-50° (or some other angle that the 40° setting hits the shoulder.)
